Re: Back to the SH with VR Problem
Posted by John T on July 27, 2009 at 20:37:10 from (66.244.97.31):
In Reply to: Back to the SH with VR Problem posted by GordoSD on July 27, 2009 at 18:58:28:
You ask about ruining a VR, if the battery was at opposite polarity then the genny that can but it dont sound like thats what happened in your case. Para 5 of my Troubleshooting procedure tells how to easily test if non charging is a genny or a VR problem (or something as simple as either the genny or VR isnt well grounded), because I dont know from here which is the cause of her not charging. Running it and or Bobs flow chart should tell you pretty quick.
See if she charges when running if you temporarily ground the gennys FLD post cuz if it charges okay then but not otherwise, the genny is okay and its either the VR is bad or not grounded.
John T
