GordoSD said: (quoted from post at 14:36:11 07/28/09) I ran the tests. When field post from gen is grounded the amm shows 25 amps. When I ran ground wire from VR base to ground, nothing!
So it is another bad VR. Which of the points should I change to see if I can get it to work?
Gordo
I know I'm jumping in the middle of you fellow's thread, but if you don't mind, I suggest that the test done where you shorted the generator Field to ground (& got 25A charging) be repeated except this time insert an ammeter between Field and ground and it will read field current. That would answer the question of whether or not an internal field short or even wrong field coils might be causing excessive field current that would damage the regulator's field contacts. I'm sure the other men know what that field current should be on your particular system, but as a ballpark number I expect ~2amps.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
