52 MD small brass insert in head
Posted by jfrankhash on July 29, 2009 at 20:09:09 from (12.213.224.36):
I have a small threaded brass nut that has a threaded hole(about 3/16's) in it in the left side of the head on my 52 MD.
It is located between the two middle fuel injectors. Any idea what this is and what its function was? Thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
