Re: 52 MD small brass insert in head
Posted by jfrankhash on July 30, 2009 at 16:00:00 from (12.213.224.54):
In Reply to: 52 MD small brass insert in head posted by jfrankhash on July 29, 2009 at 20:09:09:
This fitting is lower down on the head,between the two middle fuel injectors. It is not the vent to the air cleaner.
