Posted by Charlie Atkinson on August 01, 2009 at 15:45:49 from (24.145.46.109):
In Reply to: Re: Super A rear axle posted by Hugh MacKay on July 22, 2009 at 16:35:02:
Hugh: I pulled the axle housing off today and slid the brake drum closer towards the axle housing. I didn't have any binding and it bolted right up. I guess the brake drum was touching the differential shaft housing causing the axle to lock-up. Both axles/housings are on but I heard a noise in the left side. I started the tractor in first & second gears. Both sides have new brake bands. Thanks for your help.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
