Re: distributor plates
Posted by Charles E. McNelly III on August 01, 2009 at 18:40:29 from (67.198.56.22):
In Reply to: Re: distributor plates posted by Janicholson on August 01, 2009 at 17:09:30:
Thanks for the replys, guys. I guess finding a 25 degree plate will be tough. I have a 16 degree plate that I can elongate the hole a little until I have what I'm looking for. Thanks for the info. and help.
Charles
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
