Posted by Janicholson on August 01, 2009 at 17:09:30 from (64.61.211.127):
In Reply to: distributor plates posted by Charles E. McNelly III on August 01, 2009 at 16:38:14:
I'm not sure the advance was stamped on the plate, the advance is controlled by the weights and springs against pins on the shaft behind the plate. The total advance is determined by the maximum the rotor can turn in the advanced direction stretching the springs. It is 50% of the actual crankshaft motion, if measured directly with a protractor. thus 20 degrees of crank advance would be 10 degrees of distributor advance (measured at the distributor with a protractor. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
