Posted by pete 23 on August 01, 2009 at 19:04:24 from (173.87.8.73):
In Reply to: distributor plates posted by Charles E. McNelly III on August 01, 2009 at 16:38:14:
Ih used a 40 L , 30 L, 25 L, 22 L, 16 L, and a 8 R on farmall models, 8 R was for the diesels. Also had a R shaft for the W9 as the dist turned opposite way but don't know how many different ones . Umpteen different spring set for different rates of advance. I just measured up my M , it had a 22 degree L shaft in it , should have been 30 with flat head pistons, so I calculated how much longer to make the hole and by gosh I hit it real close first try. By the way, 16 was normally for LP gas.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
