distributor plates
Posted by Charles E. McNelly III on August 01, 2009 at 16:38:14 from (67.198.56.22):
Does anyone know which distributor plate was in the distributor on the 240 series farmall and the 340 series farmall tractors? I have seen a plate with 16L and another with 40L stamped on them. I understand that means total advance. Did IH make more then just these 2 plates? If your motor needed a total timing of 30 degrees, did IH use a 40L plate and limit the amount of total timing with heavy springs?
Thanks,
Charles
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
