Re: distributor plates
Posted by NDS on August 02, 2009 at 05:26:21 from (64.12.116.73):
In Reply to: distributor plates posted by Charles E. McNelly III on August 01, 2009 at 16:38:14:
The way the vast majority of 50 year+ old tractors are used any distribitor will work fine. Just set timing by ear and it will run fine. If you are looking for that last 1/2 HP then precision tuning may be in order. This is just my opinion but it is based on 60 years real world experience, Have swapped distributors from Ms to Hs to 400s to As and back to Super Ms and they would run good enough to suit me.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
