Re: distributor plates
Posted by jakee on August 02, 2009 at 10:46:36 from (68.40.213.253):
In Reply to: distributor plates posted by Charles E. McNelly III on August 01, 2009 at 16:38:14:
if i remember right the stamping on the plate must be doubled up to get total advance,use a advance timing light to get your total advance at full RPM.s , i would try that at 36 to 40 and watch out for spark knock,as compresion goes up timing must move back down.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
