Posted by pete 23 on August 02, 2009 at 11:11:34 from (173.87.8.73):
In Reply to: distributor plates posted by Charles E. McNelly III on August 01, 2009 at 16:38:14:
No, the number on the plate it the total advance at the engine,ie a 40 plate will give you 40 degrees advance on the crank pulley. If you don't have a advance reading timing light, it is a simple matter to measure pulley diameter and calculate distance from tdc to any degree you want to make your mark. Back when these old tractors were doing the work on the farm no one even heard of an advance timing light so we marked pulleys accordingly. Put in a lot of fire crater pistons in M's and remember 22 degree advance that came with the kit and they even sent a template along to mark pulley l 7/16 degrees btdc. The springs they sent in the kit would rarely return timing to tdc at low idle even when weights and all were new, so you had to be certain to adjust timing while running full throttle.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
