If the remote valve you have is a two way valve, it should have 4 ports. (one may be capped) does the valve connect to the top of the Liftall where the fill cap is? If so it might be a so called "christmas tree" valve with a built in return to the top fill pipe under the cap. If it just hooks to a bolted on bracket it should have a return hose connection to the reservoir. This return hose eliminates the need to push in the Liftall control rod to lower the cylinders. We will get it right. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
