Valve setting I do it this way others do a different system. It must be set cold first, so setting it twice (or once) is normal The cold setting is .020" all valves. Take out the plugs. (turn it with a wrench, on the front nut) Set the intake valve on cylinder #1 (Front) when its exhaust valve just starts to open. Set the intake when the exhaust just closes. This is the two positions that can be seen on each cylinder to be as far away from a lobe on the cam as possible while still knowing where it is. The order is (front to back EI-IE-EI-IE) Look at #1 valves, Turn the engine till the intake just starts to begin opening (moves) then adjust the exhaust valve. Rotate more until the exhaust just closes (just stops moving after having been open) and adjust the intake. Treat every cylinder (pair of valves shown above the same way, remembering they switch places between cylinders) I put a rag over the ones I have done to keep track of progress, and avoid mixing what I am looking at. Second setting warmed up, not hot, is .017" JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
