Re: Head bolts
Posted by Jeff Z. on August 03, 2009 at 13:01:56 from (74.76.3.113):
In Reply to: Head bolts posted by Bill in IL on August 03, 2009 at 12:54:33:
If you don't want to deal with the dealer you can call ARP.
ARP is a leader in studs.
They are better than alot of other suppliers because they are threaded after they are hardened. This makes for a very strong thread.
