Re: Stuck sleeves in a SA
Posted by ScottyHOMEy on August 03, 2009 at 15:42:45 from (70.105.226.246):
In Reply to: Stuck sleeves in a SA posted by TWheat on August 03, 2009 at 15:03:03:
Actually, one of the tricks for gettin them out is to weld a bead or two up the inside. When everything cools any corrosion holding them will have been broken up with the heat and cooling cycle and they will have shrunk to where they should come out without much diffugulty a tall.
