Stuck sleeves in a SA
Posted by TWheat on August 03, 2009 at 15:03:03 from (71.54.251.38):
So far I haven't budged them. The puller just cracks/crumbles the bottom of the sleeve. What about 1. cutting them out with something like a sawzall 2. Hauling it ( the tractor) to a welding shop and have them burned out? There is not a solid bearing surface on the bottom of the sleeve for the puller to work against.
