Re: Ammeter - Which way should it point?
Posted by Janicholson on August 06, 2009 at 07:19:09 from (64.83.208.148):
In Reply to: Ammeter - Which way should it point? posted by VFMerc on August 06, 2009 at 05:24:30:
With this system set on Positive ground (positive Battery wire grounded to frame) the system should show needle to left with lights on, and engine off. If it is going the opposite way, either the battery is in wrong, or the wires are backwards. I would recommend checking that befor going forward with starting. Then polarize the gen before starting. On the regulator, with it set to high charge position on the light switch, engine off, jump from the Bat terminal to tha GEN terminal (could say ARM). JimN
