Ammeter - Which way should it point?
Posted by VFMerc on August 06, 2009 at 05:24:30 from (71.188.48.104):
With the help of folks on the forum I've been able to rewire my Farmall H light box. After cleaning them up I found that both the switch and ammeter still work. When I turn on the lights (engine off) the ammeter shows the load however the neele points to the right. Is this correct or have I reversed the wires on the ammeter. I'd like to make sure ammeter is right before I fire it up. I'm relying on the ammeter to help me determine if the generator is working. Thanks
