Posted by MN Jerry on August 06, 2009 at 17:43:45 from (209.23.169.195):
In Reply to: Magneto mess posted by MN Jerry on August 05, 2009 at 21:01:39:
Well finally got the dist. cap of and am looking at the guts of the unit thats a plus considering. So now can I align the pulley so that the indicator and the two timing marks center the pin then take and rotate rotor so that it points at #1 spark plug then replace back into distributor (ended up removing virtical assembly so more than likely things are not in the same place that they were rwhen it was pulledd) and making sure the gears or seated then tighten back down turn crank slowly and see where in relation to the timing mark the breaker arm goes click
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
