Magneto mess
Posted by MN Jerry on August 05, 2009 at 21:01:39 from (209.23.168.80):
Well let me say that I thought that I had a pretty good grasp of how things worked until what I am looking at and the instruction as to getting to the breaker bar to set the points. I am working on the H and took off the dist. cap hoping that I would be able to pop off the rotor loosen three screws pop the cover and be looking at the guts of the system what I found was that the screws are on the side and to loosen them they need to come completely off and to do that I would need to unbolt and remove from magneto. Not to bad so far only problem is by doing this step I enter one more variable getting the spline gears to line up ( in the operators manual it shows that the dist. points to the back of the tractor on mine it points to the sky
