Many overhead-valve tractor engines as well as car/truck engines did not come with valve-seals new. In the 60s, Chevy small-block V8s were known to be smokers when the valve guides got worn. They had no seals when they left the factory. Had to add seals to many. Just because and engine didnt have them new doesn"t mean it doesn"t need them now. If it tends to smoke when holding back in a low gear coming down a hill, or at first start, etc, - valve-seals can probably help a lot. If it smokes when being worked, it"s more apt to be a piston/ring/cylinder problem.
I"ll add that many companies that made heavy-duty engines designed the heads and valve guides to leak a little oil and smoke, when new. The reasoning was that this added lube would extend the life of the valve stems and guides. It was also expected that once worn, seals could be added later. You can usually add seals to a four cylinder engine in an hour.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
