Re: H shutter control location and other questions
Posted by D Slater on August 09, 2009 at 12:49:49 from (72.65.153.11):
In Reply to: H shutter control location and other questions posted by Tom Fleming on August 09, 2009 at 03:29:43:
Tom thats some hard questions to give a simple or correct guarantee on the answer. Starting and lighting along with hydraulics were considered a attachment on the tractors, and there were more variations in attachments in the early models. I think the rear fuel tank support with hole for starter switch was used for all of 1942. Switch if equiped with, was operated by foot with a pin through the slanted hole in lower steering post. A steel bracket bolted to steering post for on off switch, shutter control and choke rod on 42 models. Some tractors used above mount along with the hydraulic control rod support. After posting the above you can find H tractors with parts mounted several ways. On the foot starter lever that uses a bracket that bolts to steering post. When IH came out with the hydraulic seat attachment (later than your tractor) for the tractors they came out with the foot starter bracket, because it made it hard to get at the ones with pin through steering post.
I think its the same starter bracket as M and early SM tractors.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
