Farmall F-20
Posted by K S on August 09, 2009 at 13:28:10 from (69.146.99.2):
I"m restoring a 1937 Farmall F-20. On the right side of the steering wheel shaft there are two levers one is attached to a shaft and the other is attached to a tube that has the shaft inside it. The tube ends above the magneto to turn the magneto on and off. The shaft extends to the front end of the hood. What is the second lever and shaft for?
