Re: Farmall F-20
Posted by garytomaszewski on August 09, 2009 at 14:24:42 from (4.131.19.129):
In Reply to: Farmall F-20 posted by K S on August 09, 2009 at 13:28:10:
These were a throttle control before someone "updated" the governor. If you look at the front of the tube from the carb there shoud be a lever with a hole in it that used to be the throttle control. Tom, all my shutter controls were mounted on the gas tank brackets, one side had manifold heat control the other was the shutter control.
