Re: B Farmall Zenith Carb
Posted by gene bender on August 09, 2009 at 18:40:26 from (67.55.227.88):
In Reply to: B Farmall Zenith Carb posted by MNGB on August 09, 2009 at 17:28:40:
Two things mite need to clean the carb and how much slop does the input shaft of the gov have that can make for some awful speed control. I rebush them and if the rest is adjusted and a clean carb they run and idle just like new. Adjusting the t-handle on the main jet should make a big difference in engine operation.
