Posted by MNGB on August 09, 2009 at 19:29:13 from (69.42.227.214):
In Reply to: B Farmall Zenith Carb posted by gene bender on August 09, 2009 at 18:40:26:
Yes I know about the fun of getting at the idle stop screw, it is off the stop.
The carb is clean, really no slop in the input shaft, as I posted earlier I've adjusted the idle screw the idle stop screw is not on the stop peg, I've adjusted the linkage per the manual, have tried adjusting the surge screw on the bottom of the gov but that makes no difference. And as I say screwing the "T" jet screw all the way in does not have any effect on engine revs, It does make a difference when power is required thus I turned the jet out about 2.25 turns and the engine runs good has good power. On other carbs when the main jet is run all the way in they generally sputter and stop not this one.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
