Pretty common for the TA equipped tractors to take a while for gears to stop turning as you have a couple things going on that is normal. One is, the mass of the ta itself spinning, then you have live pto shaft running in oil through transmission lower shaft with a tendency to keep counter shaft rotating. Also, if you use the metalic, (dyna life clutch disc) it is even worse.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
