Barn Found 22-36, What's it worth?
Posted by PaceF20s on August 10, 2009 at 17:46:59 from (12.202.50.117):
third party image
third party image
third party image
I've uploaded three images of the 22-36 that I found in a barn. The hood was removed long ago at another site. The tractor's working life was spent mostly running irrigation pumps in South Florida cane fields. I guess that means that the engine has lots of time on it, but the running gear doesn't. The engine turns but has no compression. I'm guessing (hoping) that the valves are stuck open. Other than the starting gas tank, hood, side covers, lugs, and skid rings off the front wheels, most everything else appears to be there. It does have the original water injection manifold. I'm thinking it might be worth $1000. Is that about right? Any help is appreciated. Thanks, Roland
