Posted by MNGB on August 11, 2009 at 10:44:07 from (69.42.227.214):
In Reply to: B Farmall Zenith Carb posted by jamieei on August 10, 2009 at 15:41:32:
Hi jamieei, I worked on it yesterday got it somewhat better, I'm thinking some of my problem is that the throttle lever on the carb has slipped in the past someone tried to braze it and not knowing the exact location / setting makes it hard to rig right. The engine runs good under a load the top rpm's are right it's just does want to idle below 900/1000 unloaded, also when unloaded there is no rpm increase as the throttle lever is advanced untill the last 1/2 inch of travel.
Yes I read about adjusting the surge spring only about 1/2 turn at a time and that too much will cause high idle, I'm thinking like you that the spring maybe weak as any adjustments I've made has had no effect on surge or idle. I'm going to see if I can barrow a carb off my brothers tractor and see if it will run better. Please keep me posted as to what your finding and I'll do the same, thanks
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
