Posted by Bob M on August 12, 2009 at 11:31:26 from (151.190.254.108):
In Reply to: Why does it stall? posted by Iowaboy on August 12, 2009 at 06:08:10:
I agree with Andrew - likely the long trailer ride dislodged some crud in the carburetor and it's now partially plugging one of the fuel metering orifices.
Or if it's a steep climb on/off your trailer water and junk in lying at the bottom of the float bowl got "sloshed" into a fuel orifice.
Whatever the cause suggest dropping the carb bowl. It can be done without removing the carburetor.
Once the bowl is off thoroughly clean the interior and blow out all the passages. Also blow out the passages in the throttle body casting, and remove/clean the fuel inlet screen (it's located behind the fuel line inlet nut).
Reassemble using a new gasket and see if it solves the problem.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
