Re: trying to set ingnition timing on farmal m
Posted by ScottyHOMEy on August 13, 2009 at 10:13:25 from (70.105.238.88):
In Reply to: Re: trying to set ingnition timing on farmal m posted by D Slater on August 13, 2009 at 09:36:13:
Good catch! And no apology needed. You read it right. I remembered to double the advance numbers but not the rpms from the chart.
Brian, those should read
0-400 rpms -- TDC (that's about as low as you can hope for it to idle)
1200 rpms -- 34 BTDC
1600 rpms -- 40 BTDC (which is pretty much the wide open running James referred to when setting timing)
And D Slater's note about modification over the years might explain any variance you find from those numbers, too, when you get it running right, as well as the slop from wear that James cited.
Sorry, Brian, for the confusion. But we're all still on the same page.
