Re: gas flow 1952 Farmall C
Posted by Shawn in PA on August 14, 2009 at 15:25:50 from (72.23.162.33):
In Reply to: gas flow 1952 Farmall C posted by Ron Corkum on August 14, 2009 at 15:15:42:
Pull your lines and filter and check for a blockage. If that doesn"t work try blowing some air back through the fuel line into the fuel tank. Eventually you might have to pull the tank entirely and clean out the 60 year old rust inside. This happened to me once on my M.
