Posted by Ron Corkum on August 14, 2009 at 15:15:42 from (71.7.157.140):
1952 farmall C . what should I be looking for to cure a gas flow problem. The tractor runs fine for a short while if I remove the gas tank cover blow pressure into the tank until gas drips from the carburetor bleeder.I close the bledder start the tractor and procede the flow is too slow for the engine usage and after a short time it begins to cut out and eventually stops.I repeat the process and off I go for another stint. The gas bowl pit cock is turned straight up,is this ok? Could their be a blockage at the tank /bowl connection,and finally could there be a losse connection allowing air into the line? How should I approach this problem?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
