Farmall Cub Electrical
Posted by CT_Farmall on August 14, 2009 at 23:41:12 from (64.252.91.203):
I just pulled in a 1953 FCub that I was going through and getting in shape this evening. I noticed that this tractor has a 6V distributor ignition. As I was cleaning up the wiring on the battery and removing the corrosion I noticed that the negative was to ground and positive was to the starter. I thought all of the earlier machinery was positive ground. It will start with the negative ground but what is the correct set-up? If I swap the grounds do I need to make any other circuit changes?
Thanks in Advance
CT
