Re: Farmall Cub Electrical
Posted by CT_Farmall on August 15, 2009 at 11:01:47 from (64.252.53.114):
In Reply to: Farmall Cub Electrical posted by Bob on August 14, 2009 at 23:41:12:
John T said: (quoted from post at 17:46:56 08/15/09) Okay, when not running if you turn lights on she swings to + charge THE AMMETER IS BACKWARDS probably cuz it was originally pos ground but got switched to neg ground and no one reversed ammeter leads.
If its charging when running at fast RPM with a backwards ammeter (like you have) it would swing over to - discharge THAT WILL TELL IF ITS CHARGING OR NOT even tho ammeter may be backwards
Measure battery voltage just setting it should be around 6.3 volts for a 6 volt or 12.6 for a 12. Then when running at fast RPM if shes charging the battery voltage will rise to the 6.5 to 7 or so range, twice that on a 12 volt system.
Heres how to troubleshoot non charging
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=665110
John T
John Ts Troubleshooting
Thanks John,
I will get into it tonight. Will post results later. I don't think it is charging because at high rpm idle the needle of the ammeter is at dead center.
Tim
Tim
