Posted by pete 23 on August 15, 2009 at 11:06:20 from (173.87.8.73):
In Reply to: H Head Job posted by C1802362 on August 15, 2009 at 09:20:00:
If it smokes on start up, high vacuum conditions like coasting etc a good set of valve seals would probably help a lot . If you pull head, original pistons were cast iron, 3 3/8 bore, next was aluminum 3 3/8 and then later thin wall sleeve 3 7/16 bore aluminum. It most likely has been apart a few times, maybe several and needs to be pulled down again.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
