400 from hell
Posted by Dodger 45 on August 17, 2009 at 14:43:22 from (208.126.117.86):
I bought a 400 international over a year ago. I drove it 5 miles home. It ran a little rough but the points were bad. During the next few weeds, I did a little work on it. The only problem is that it just kept getting worse till it would not start. I called in two guys who are very good at old tractors. They both gave up. At this time it is timed correctly using valve position and timing marks and rotor position. The carb has been gone through four times. It will suck your hand into the carb intake so it is pulling air. When we try to start it we choke it till the carb has gas running out of it and choke by hand, but the plugs never get wet. The starter and battery are new. It makes no sense. Help !!
