Re: 400 from hell
Posted by Brownie 450 on August 17, 2009 at 15:42:21 from (66.43.241.141):
In Reply to: 400 from hell posted by Dodger 45 on August 17, 2009 at 14:43:22:
Have you put gas in the spark plug holes & then tried to start it? You can put some gas in a pump oiler to get fuel in the cylinders. You have vacuum, but how much---which cylinders? Have you checked the valve clearance? Might be tight on a couple of valves. I'd try pulling it to start if trying the gas in the cylinder doesn't work.
