Re: 140 no compression
Posted by Brad M-C on August 18, 2009 at 13:52:38 from (74.131.54.89):
In Reply to: Re: 140 no compression posted by ScottyHOMEy on August 18, 2009 at 13:31:16:
I pulled the rocker assembly and ran compression again and still get zero on all cylinders, even with a little oil. I can pump air into the cylinder with an air pump and the motor will not turn over, but i cannot hear where the air is comming back out at. Can the rings be checked without pulling the piston?
