"Can the rings be checked without pulling the piston?"
If you've got a good ear and an airhose, you can try, one cylinder at a time. Hook whatever you're using to put air into the cylinders up. Best is a hose from a compressor with the tank pressure up and the power off. Set your regulator at 100# or so and put the air in and listen. Turn the motor one cylinder at a time and test the one where both valves appear to be closed. (If the rocker is off, they should all be closed, if not, closed vlaves are indicated by a gap between the rocker face and valve stem). If you get a sound of escaping air from the exhaust pipe on top of the manifold, there's an exhaust valve stuck open on that cylinder. If you have air leaking back out through the carb (it helps to remove the hose between the air cleaner and carb, it's an intake valve stuck. You might have to drop the pan to hear it, but if the sound seems to be coming from the bottom of the motor, you can suspect your rings. If you've still got a lot of oil in your cylinders, you may hear a drip in the pan instead of an air leak, as the oil is forced out. If it bubbles or hisses out through your radiator, think head gasket.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
