Re: 140 gearbox and PTO oil amounts
Posted by Red Dog on August 20, 2009 at 03:43:42 from (64.252.199.61):
In Reply to: Re: 140 gearbox and PTO oil amounts posted by Hugh MacKay on August 20, 2009 at 02:08:09:
I understand. Thanks. Also I noticed this one two different 140's. If the right angle drive is removed, the shifter grinds a little putting the tractors in gear. Is this common or why does it happen? Do I need to adjust the clutches when removing a right ngle drive. Both tractors want to grind without this side drive on. They go into gear but I hate that little bit of grind. Whichever tractor is not going to have this drive on it is going to grind some. Thanks.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
