Re: 140 gearbox and PTO oil amounts
Posted by Hugh MacKay on August 20, 2009 at 14:17:00 from (209.226.247.135):
In Reply to: Re: 140 gearbox and PTO oil amounts posted by Red Dog on August 20, 2009 at 03:43:42:
Red Dog: I've never had belt pulley gear box on my 130 or 140, so I can't comment on that idea. I can't see how the belt pulley gear box could make any difference.
All these offset tractors should have gear oil 90W or heavier, I don't care what IH said, heavy oil helps slow those gears when you depress the clutch. Another item that helps is hold shift lever as if you were putting it in a gear opposite reverse. Just hold it against that with clutch depressed, you'll be surprised how quick the gears stop.
