Re: 340 water pump
Posted by Brownie 450 on August 20, 2009 at 04:01:31 from (66.43.241.141):
In Reply to: 340 water pump posted by moondoggie on August 19, 2009 at 20:35:18:
If the thermostat is known to be good, could be the impeller has come loose from the pump shaft & isn't turning. Possible that a piece of radiator hose has come loose & is blocking coolant flow.
Have you checked the water temp with a thermometer? What is the reading? How full is the radiator? If it is clear full, you might not see any turbulance from the pump.
