Re: 340 water pump
Posted by Moondoggie on August 20, 2009 at 18:36:38 from (66.187.36.35):
In Reply to: Re: 340 water pump posted by Brownie 450 on August 20, 2009 at 04:01:31:
Thank you. I'll try the temp test this weekend. The liquid level is about 1-2 inches below the bottom of the filler neck. I'll draw it down to about an inch above the inside and see if there's any fluid movement. (Try the simple things first). Thanx again.
