Re: 806 hydraulics under load....
Posted by scot in pa on August 20, 2009 at 13:16:29 from (12.171.163.27):
In Reply to: 806 hydraulics under load.... posted by Dan Swanson on August 19, 2009 at 18:57:14:
I think that the depth pin on the cylinder is a shutoff valve, not a by-pass valve. It should kick your spool valve into neutral. When the pressure hits the back side of it, it resets. once you hit your depth, kick your lever back into neutral and out of drop.
From what I have read on some 00 series literature, the quick hitch is set up like that, so when the paddle hits the pin it spikes the pressure in the circuit and kicks the spool into neutral.
