Posted by Dan Swanson on August 19, 2009 at 18:57:14 from (63.172.252.199):
Was working summer fallow today with my 806 and a 14' set of sweeps and dead rod. It has always seemed the tractor was under more load than it should be. I set the cylinder so that I was getting the weeds with the rod but still had weight on the wheels of the sweeps. I have an old case cylinder with the control pin that hits an adjustable collar on the ram for dept control. Any way for what ever reason I put the valve into float position,(pushed it clear forward). The tractor immediately smoothed out and ran a lot easier. Wasn't acting like it was under any load as before. So I played with several times and everytime I let the sweeps down and left in the normal position, the tractor seemed loaded more. Put in the float position and the tractor ran a lot better like it should. Might the problem be that the valve is constantly bypassing and needs rebuilt. Or, might it have something to do with the case cylinder? I am going to switch the hoses to the right set of outlets that are controlled by the right lever and see if it is any different. Any ideas? Thanks Dan
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
