Farmall B sparkplug question
Posted by Rossputin on August 20, 2009 at 18:42:30 from (72.42.107.108):
Hi Gang,
For my 1941 Farmall B with an H-4 magneto and a crank starter, I just got some Autolite 3116 spark plugs based on a recommendation I got here.
Now here's my question: I recall seeing, in two different places, two different recommendations for the spark gap.
Can anyone give me anything like definitive advice on the proper gap?
Is it OK to use needle-nose pliers to adjust the gap if it needs adjustment or should I get something else?
Also, is it relevant that I'm at 8,300 feet of altitude? (And in general, how does that fact figure into anything else I might be doing to adjust or maintain the tractor?)
Thanks as always!
Ross
