Gapping with pliers is OK if you don't get into the center insulator and leave a metal smear. .025 to .026" is good. If it came from sea level to 2000 ft, it could be set leaner to run well. A smaller carb jet for the main , and a turn or so on the idle mix. (jets might be hard to find) If it is from high altitude sales, it will be OK as is. Use copper core (real wire ) spark plug wire, or Magnetic Suppression wire. (coiled real wire around a core of fibers) These have no resistance to spark, and will do well. At 8000ft, it will have about 8 to 10% less power, but that is OK as they have plenty. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
