Re: Farmall Cub snow blade fitting/converting to a Farmall A
Posted by mkirsch on August 21, 2009 at 05:02:11 from (64.80.108.57):
In Reply to: Farmall Cub snow blade fitting/converting to a Farmall A posted by gocartbuilder on August 20, 2009 at 21:07:07:
gocartbuilder said: (quoted from post at 21:07:07 08/20/09) Thought I would place this in the correct sequence! I have a manual lift; same one I use for lifting my cultivators. I am quite handy with welding and metal fabrication, so making or adapting brackets or plates to fit the wider and longer A should not be a big problem. I was already planing on extending the blade to about 66". I can pick up a complete Cub blade for $75 or an A blade for $$375. After my initial post, I went searching and I did find a post from a few years ago with a photo and description of someone doing this conversion. It looked pretty good.
If all that is true then what is your question? Get going!
